tv has no display backlight is working and laptop detects tv
tv has no display backlight is working and laptop detects tv. i dont see startup screen or menu when pressing menus on remote.
thank you for any suggestions
Esta é uma boa pergunta?
Hi,
Just confirming that the TV has a lit screen (backlights are on) but no video display, is this correct?
Also is there audio at all?
Check the connections between the mainboard and the tcon board and also between the tcon board and the panel itself (be careful with these as the panel connections are delicate)
Also check if there is power to the tcon board.There is usually a fuse on the tcon where it can be measured, just to see if it is there.
No video display is either the mainboard, the tcon board or the connections in between.
What is the model number if not a UA40F5500AM?
Esta resposta foi útil?
adding to this....also panel... do tcon/ panel test google/youtube. one ribbon at a time. should be nothing but a black or white clear screen on side where ribbon cable is disconnected. if any lines/bars appear....panel fault
thank you
model is ua40f5000ar… i will test lvds, tcon and panel…
the tcon has 3 blue leds on when turned on but have notchecked the fuse yet…
no sound as well
If there are lights on the tcon board then there is power there.
This doesn't mean that it is working properly though.
Having no audio also is a worry as this is the mainboard, nothing to do with the connection to the tcon, the tcon or the panel, so it's starting to look like it might be the mainboard.
It could also be a firmware problem (which is on the mainboard anyway stored in an eeprom)
Perhaps try reinstalling the firmware(scroll down to Downloads > Upgrade file).
Read the upgrade guide to see how to do this.
I'm not sure that this will even work because with a lot of TV makes you cannot reinstall the same version software, only higher versions and also in your case you cannot view the menu screens to initiate the update.
What I am hoping for (and I don't know) is that by starting the update procedure i.e. inserting the USB with the correct file loaded as per the guide, maybe it will turn on a section of the existing firmware which may not be corrupted and that will show the menu screens to allow for the update to begin as described in the guide but I wouldn't be surprised if it did nothing at all either. At this stage you don't have much to lose by trying.
Check that I have linked the correct model. Loading the wrong firmware can "brick" a TV. Search for "Samsung (insert full model number) support" to double check.
thank you jayeff i will try the upgrade. hopefully it works.
Hi you have to check every single led in the stripes. When a single led is faulty all the stripe is off and IF 2 stripes are on the same power line power supply goes in protection and switch off both of them
As the previous poster said this will either be (in order of probability) a T-Con fault, Panel fault or main board. If it's the panel then there's nothing to be done but do the voltage checks on the T-con look for the fuse and test both sides - multi-meter set in DC Volts - multi-meter black (neg ) lead touch to chassis and red lead touch to fuse if you get voltage on one side (between 12-14vdc) but not the other it's a tcon fault - if you get no voltage on either side - main board fault.
When it comes to a backlight no image fault and replacing parts, as well as making sure you get the correct BN4*-****** numbers you have to ensure you get the part which matches the screen number too - the screen number will be on a big sticker on the metal chassis - usually visible but sometimes hidden behind a board, for a 50 inch samsung the screen number should start with VES50*********
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 441
