Ir para o conteúdo principal
Guides and repair information for coffee and espresso makers from Jura Elektroapparate AG, a Swiss developer and distributor of home appliances.
coffee beans won't grind
grinder makes grinding noise but does not grab the beans (fill beans demand) I already emptied all the beans out and let it ‘dry’ according to helpline but it still does not work
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Do you see the impeller spinning? Using a plastic straw wedging it into the blade does the blade have force?
My coffee grinder (different) had a sheer pin which snapped so the impeller was not secured to the motors axle so the motor ran just no grinding!
Use care! As you don’t want to use much force holding the impeller and you don’t want to put your fingers at risk either!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
anja será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 541
