Ir para o conteúdo principal
The Lenovo IdeaPad Flex 4-1470 Model Name: 80SA , manufactured in 2016, features a 14 inch touch screen display which folds around 360 degrees to be used like a tablet.
9 Perguntas Visualizar todos
How you you replace touch screen?
I have purchased a touch screen replacement for my laptop and need the steps to remove the old and replace with the new screen.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
Is the touchscreen physically damaged or is it just that it doesn’t work?
If just not working have you checked the status of the touchscreen in Device Manager > Human Interface Devices > HID Compliant touchscreen to see if it is OK?
Here’s the hardware maintenance manual for the laptop.
Go to p.56 to view the necessary pre-requisite steps and then the procedure to remove the LCD unit.
It’s interesting to note that the manual doesn’t show the touchscreen as a separate component in the LCD FRU diagram on p.80 or in the parts list on p.81 or in the parts list on the Lenovo support page for the laptop. Click on Select commodity > LCD Assemblies
Hopefully this doesn’t mean that it is an integrated assembly, LCD and touchscreen combined. Just a thought.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Erich Kessel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 58
