I want to erase memory from phone
Esta é uma boa pergunta?
bahamaina, this will clear ALL YOUR INFORMATION, so only do it if that is what you need to do. The 680 does not have a reset button, so you need to use the battery as reset button:
-Remove the battery,
-Insert the battery, and immediately press and hold the power button.
-Wait till the first time-bar is fully loaded, and the palm logo
shows, if you can't see the screen because it is cracked, just hold
the power button for 1 minute.
-Release the power button,
-The screen says now: erase all data ? (Yes = up, No = other button)
-press the 5-way navigator to the UP position.
-Now the PDA is erasing user data. This will take about 10 seconds.
Hope this is the information you needed. Good Luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 745
1 comentário
Give us a bit more info about what you are trying to do? you want to clear some memory? Are you running out of memory?
por oldturkey03
