Ir para o conteúdo principal
Repair guides and support for your Philips TV.
241 Perguntas Visualizar todos
no display problem in tv philips 32pfl3409 98
The power is On , the LED indicator for power is on, but the tv have no display. there is no respond with the remote control nor with the power switch on the tv. I put off the tv and wait, I put it on again but same problem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
sounds like there is no logic function on your mainboard. this is most likely the issue. to test, youll require a multimeter and the ability to use it. let us know if you do and can for further assistance.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Shiv SEEPERSON será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 241
