Powers on for spit sec with beep and blue light then powers off
i just replaced the power supply thinking that would do it, (maybe faulty) but it didn’t. I have cleaned it, tried letting it set unplugged and restarting it nothing has worked. I wanted to try the “Washer Fix” but i have a 1215a model where the heat sink clamp is under the cover and i cant fit the washers on the screws under it. Any ideas would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação
0
My PS4 encountered a semi-related problem, where the power light would fade out from blue instead of switching to white when booting, but this had no adverse effects on the console.
por Michael Deitz
Check the 2 pins that go into the psu are straight.
por daniel
would that give me these result or no power at all?
por Infamous Inferno
It could. Only if the two pins are touching together which at this rate it'll probably be very hard to remove the power supply.
It's either a bad power supply or APU fault. If it's APU fault then this console is pretty much gone.
por Ben
Iv had it before without the pins touching, if the pins are touching then it won’t go into the psu.
por daniel
