Ir para o conteúdo principal
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
398 Perguntas Visualizar todos
iPhone xs rear camera lens assy replacement, just lens not an option
Ok guys, have to change out the rear camera whole lens assy. How do I do that? Changing out just the lens is not an option. I think I need to pull out the bracket that holds the rear cameras but not really seeing a way to accomplish that. Plus I already have to change the power button, flash, and prox sensor cable so I’m already in the area, have the cameras out but cannot see how that bracket comes out. Or if I can just get the lens assy off without removing that bracket, that would be good too. Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You can take out the lens with a heat gun, make sure you take out the logic bord first, to prevent damage it by high temperature
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Darryl Sledge será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 49
