Why is the bottom part of my Samsung S10 flickering after it cracked
I dropped my phone and it cracked on the edge, after it started flickering on the bottom half, now its permanent
Esta é uma boa pergunta?
You may have damaged either the screen cable or the pixels inside the display. Can you provide pictures of the damage?
Esta resposta foi útil?
You have unfortunately damaged the LCD within the phone. Thus causing the flickering or permanent black or green line. If you turn the phone off and look under extreme light you will notice a crack on the LCD. Best option for this is a replacement screen.
Hi, thanks so will the phone die eventually?
i have the same issue and sometimes my screen is flickering and turning white, then another time its just fine
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 3,823
