Ir para o conteúdo principal
Won't charge or turn on after using a car charger
Hi everyone. Really need help with my iphone 6. The device was plugged into a car charger but remained on 2% throughout and didn't increase in charge. Now the device is off and refused to charge, turn on or reboot despite using different charging options. I tried a wall outlet, the computer, a different cable. I'm afraid the car charger might have damaged it somehow. Please assist me to fix it. Thank you in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Car chargers can do this to phones especially the iPhones. You first should make sure it is not the battery. If it is not it will be a damaged Tristar charging chip on your logic board and it will need to be replaced. This is not an expensive repair for the iPhone 6 although it does require microsoldering.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kim será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 97
