Won't play without being plugged in
My UE Megaboom will only play when it’s plugged in.
It will flash like it is charging for around a minute then the light will go out and nothing happens. If I turn it on while plugged in, it will turn itself off after around 10 seconds unless I am running something through it. I have tried resetting and replacing the battery with the same results. The speakers crackle at high volumes but I am sure this issue is unrelated.
It would be a shame to throw this thing away because they are great when working properly.
The only thing I can think is that it is not charging because initially it was turning off and on every few seconds but now I also get the critical battery warning if I don’t play something through it. So the power must be getting through.
Any ideas????
thanks
Esta é uma boa pergunta?
