Is it possible to replace the screen enclosure/chassi?
I have dropped my MBP 16” and the chassi/enclosure/lid whatever it’s called is damaged. But the screen seems fine! Can I change the enclosure/chassi/lid only ?
Esta é uma boa pergunta?
This gets into what Apple offers for parts and what we can get. Apple has reduced the SKU count quite significantly other than fasteners its less than 20!
So to fix your system you will need to find another lid assembly who’s LCD is damaged so you can swap out your good LCD to the good lid shell. As this is such a new system finding a broken part to do this will be tough!
Then you need to consider the amount of work to take your good display out of the shell without breaking it.
In the end I think it’s just easier and in the long haul its just cheaper to just replace the full assembly as this is a very difficult screen to open.
Yes, I know it’s a lot of money, I wish Apple had designed things better making these newer systems more serviceable. I can tell you I’ve seen good design thats both easier to assemble and service! Apple likes making there stuff harder to fix each generation.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 168
