Is it ok for me to put the entire logic board into isopropyl alchohol
Is it ok for me to put this entire logic board into 70% isopropyl alchohol? Its a last ditch effort to save puctures
Esta é uma boa pergunta?
I believe it would be ok, submerging in rubbing alcohol is a standard practice, let it sit for an hour or two and it may solve your problem.
Esta resposta foi útil?
is 70 isopropyl good enough to do it? Every other type is sold out everywhere
90% or above is whats reccommended but if you wanna take the chance it could still work.
thank you so much
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 97
6 comentários
also how long should i let it sit there
por Dylan Devries
any help would be nice
por Dylan Devries
@Dylan Devries
70% isopropyl alcoholis to to disinfect like for Covid-19 bought at pharmacy.
100% isoprophl alcohol (no water) is for cleaning electronics bought at electronic store.
Remember - highly flammable !!!
But before using alcohol would you answers these questions as you did not really say what your problem was ?
* What happened?
* You wrote "...save puctures (picture I guess?)".
* Are they not on your SD card? Please explain.
* And why do you think alcohol will help?
por mike
Sorry, My grandpa fell in a lake, his phone was wet, and got stuck in a bootloop. I fixed it by using 70 percent alcohol because everyone around me is making hand sanitizer with it. He had no SD card in it. Alcohol is meant to displace the water, and i used it because he needed his pictures back. It ended up being the battery that was causing the issue
por Dylan Devries
Hi @Dylan Devries ,
Glad to hear you solved the problem. Your grandpa was very lucky.
por mike
Exibir mais 1 comentário
