Ir para o conteúdo principal
Device stuck in recovery mode - iTunes won't download IPSW
I recently purchased a second hand iPod touch 1st gen, it’s currently running FW version 1.1.5 (I think). It’s stuck in recovery mode and no amount of forcing it out is working.
When I connect it to iTunes, it is recognised as in recovery mode and I am prompted that I must restore it to use with iTunes - fine.
I click OK, and click Restore, then “Restore and Update”
Now, I know that the latest supported FW of the 1st gen is 3.1.3, however by default, iTunes is trying to “Restore and Update” the device to 2.2.1
I click next and agree to the T’s and C’s
However, I then get this error
I can only assume it’s because iTunes is trying to download an IPSW that is no longer available, as Apple will not sign 2.2.1 any more. I tried finding the 2.2.1 IPSW online just to see if I could even get a little further than I am currently but can’t find it for this device anywhere. I have tried the process using older versions of iTunes (tried 11.0, a version of 10 and a version of 9). So far I have also tried using the “Tenor Reiboot” app to kick it out of Recovery mode which didn’t work, and I begrudge paying the £40 for the pro version to test any further on a device I only paid £15 for in the first place.
If possible, it would be nice to keep the device on an older FW, be that 1.1.5 or 2.2.1, but at this point, I will settle for getting it working on 3.1.3. Although, I have tried finding the 3.1.3 FW and can’t find that anywhere either.
Any help is greatly appreciated! I hope I’ve provided enough info.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try holding the SHIFT key when you click the restore button. (or the command key if you are on mac) This will allow you to select a custom firmware.
they are available for the iPod touch 1 here: https://ipsw.me/iPod1,1
the top one should work for you
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Matthew Dakin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 157
