Sanyo DP39E23 turns on for 15 minutes then the screen goes black
Hi!
I have a Sanyo DP39E23 that I got from a family member. They gave it to me because it would work perfectly for a while and then the screen will go black with the audio still running. I looked into getting a different main board as that sounds to be a common problem, but I’m not sure if the board is even faulty. What should I do?
Edit: The power supply makes an audible whine when the backlight goes out. Also, it seems that one of the corners warms up but none of the other do.
Esta é uma boa pergunta?
