Ir para o conteúdo principal
Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
My Xbox doesn't turn on
Since I got my Xbox it hadn’t turned on. Then I decided to take it apart. I disconnected the dvd drive cable from the motherboard, ad then it turned on. I connected it again and it will not turn on again. I hope that someone can help me with this problem.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Why exactly did you disconnect the disk drive??????? That has nothing to do with power?????? Anyways, check if the power brick is plugged in. Both wall outlet and console.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Seb será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 457
