How to repair seam on leggings
The front seam on my Peak Mission Tights has given out in a couple spots so there are a couple holes along the seam. How would I repair this with a strong stitch to hold them together?
Esta é uma boa pergunta?
If I had access to a sewing machine I would double stitch it, the principle for hand repair is the same.
Choose a similar colour polyester thread stitch over on the same spot to secure thread using small stitches, sew a row of running stitches where you see the original stitching would have been. When you get to one end turn around and resew the same line carefully sewing in between along the first row you sewed, if some seams have started coming undone, it's important to do the whole seam as it is likely the rest break. Don't forget to stitch over in the same spot to finish.
Esta resposta foi útil?
Here’s the guide on repairing a seam:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 40
Duração total: 2,568
