iPad Pro 11" Not charging after screen replacement
iPad Pro 11" Not charging after screen replacement. I replaced the screen and now the device only pulls around 0.1-0.2 from ammeter. Should I be considering replacing the battery or is there a component on the logic board possibly damaged?
Esta é uma boa pergunta?
Update: When I disconnect the battery the ammeter shows the device pulling the proper voltage, the device boot loops, but if I screw or hold down the battery connector while it starts booting with the battery disconnected the device powers on and appears to be charging with the proper voltage but when the screen shuts off the amperage drops and the device dies.
por Randy Northrup
