Witch differential oil to use
Anyone know the exact differential oil for 2000 Dodge dakota 2wd? Not sure to use 75w90 or 80w90.
Esta é uma boa pergunta?
It should tell you in the owners manual but there isn't a big difference you can use 75/90 80/90 it doesn't really matter. You can use standard or synthetic. The only thing you do need is the additive if you have a limited slip differential. If only 1 tire spins in the snow then you don't have a limited slip differential.
Esta resposta foi útil?
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 55
Duração total: 1,672
