Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronuncia-se com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
Dropped my iPhone X. No cracks but display gone black.
I dropped my phone accidentally. NO CRACKS in glass and touch screen is working fine but DISPLAY gone BLACK. I’m receiving Notifications, calls and speakers are working fine.
what might be the problem?
Do you think my screen is damaged?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
2 respostas
Pergunta mais útil
There could be a few causes, the most obvious being the OLED screen could have damage underneath the glass that is keeping the screen from powering on and in this case you would need a display replacement.
Another possibility is it could be software related have you tried to do the soft reset of the phone by tapping volume up then volume down and holding the power button until the phone power cycles? I have seen a few instances where this happens and does fix the problem.
The only next step that you could take would be opening up the phone and reconnecting the display connections to make sure nothing came loose if that doesn’t work then you definitely need a display replacement.
Esta resposta foi útil?
Pontuação 1
It sounds like you need a new screen.
Pontuação 0
Adicionar a sua resposta
Thriven Kumar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 8,482
