Ir para o conteúdo principal
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Perguntas Visualizar todos
Pull the vertical sync ribbon cable out of its socket?
Just curious: is this a rigid cable that will slide back into place once I am reassembling it? Anything else I should know about it?
Thanks
Will
Update
btw, what is this cable for anyway? and if broken, how vital and costly is it to replace?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
I just broke my cabel, what does it do? -It seems to work fine without the cabel..
/Jimmi
por
Adicionar um comentário
3 respostas
Solução escolhida
It is a rigid cable that slides into its socket. You can see this up close in step 5 here.
Esta resposta foi útil?
Pontuação 3
I haven't been into this one yet, but be sure there is not a little brown plastic flip up holding it in place. These are very easy to overlook and oh so easy to break and impossible to get the part to repair it
Pontuação 2
Try this:
http://www.applecomponents.com/items/000...
This replaces the V-Synch ribbon cable for the late 27" 2009 iMac...
Pontuação 0
Adicionar a sua resposta
William Evans será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 9,776
