Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
iPhone SE (1st gen) doesn't charge + randomly reboots
Hi there! I got an iPhone SE (1st gen) that wouldn’t turn on. (Showed the Apple logo and immediately turned off again.) On opening it, I discovered that a third party battery had been installed. (Branded “LTZGO” and labelled as “high capacity, 1800mAH”.)
I switched out the battery and tried an iFixit model as well as an old original Apple battery. The iPhone boots fine now and everything works, but:
  • When plugged in it shows “charging” but the battery percentage doesn’t change.
  • The phone randomly reboots after a couple of minutes of use.
It’s got iOS 13.5 installed.
Is there anything I can try to narrow down the problem further? Is this salvageable? Or does it sound like a logic board problem?
Any help is greatly appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
It could possibly have a bad charging port. It could also have a bad tristar ic which controls charging and data transfer. You can have a shop check the tristar with a tristar tester.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thank you Allan! I'll check that out. Should the tristar be damaged does that damage the charging port? Or can I safely switch in a known good charging port without risking damaging that one too?
por
No it doesn't have any affect on the charging port. One of the reasons that the tristar ic is damaged is using an aftermarket charging cable that isn't MFI Certified. MFI Certified means that Apple approved the cable and it meets their specifications. The cheaper ones don't have have the correct ic chip and it can cause power spikes and damage the chip.
por
Thank you very much, @barriphone ! I'll try replacing the charging port and if that's not it, I'll look for someone who can replace the tristar.
por
I have one with the exact same symptoms. A new charging port stopped the random reboot but it won’t charge. My next step is Tristar and maybe Tigris once i’m there.
Hope that works or i won’t go beyond with this lil buddy.
Pontuação 0
Adicionar a sua resposta
Benedikt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 512
