Ir para o conteúdo principal
Liberado em abril de 2010 com as opções de processador i5 de 2,4, 2,53 GHz Core ou i7 de 2,66, 2,8 GHz Core
591 Perguntas Visualizar todos
MacBook Pro 15" Mid 2010 Airport card upgrade to early 2011 card?
I have a Macbook Pro 15" Unibody Mid 2010 that was dropped. I have replaced most of the parts, but I can't find an antenna for the airport card.
I have found an antenna for an Early 2011 Macbook Pro 15". In the teardown guides, all of the wireless parts look like they could be swapped out.
Does anyone know if it is possible to upgrade my Mid-2010 airport system to the newer Early-2011 airport system?
Thanks,
Chris
Update (04/21/2016)
I found an antenna on eBay. I did not choose to upgrade the card or antennas.
Esta é uma boa pergunta?
Pontuação 2
8 comentários
Did it work?
Please let us know.
por
Also interested in knowing if this worked. I want to get Bluetooth 4.0 on my 2010 MBP as well.
por
You can. Just installed a BT LE card on mine. However it requires a few modifications. 1: cut out new holes for the plastic container or order the 2013 part. 2: connect the wifi plug to J0 and J1 (there is no cable for J3) 3: the cable that goes to the MB is a bit to long. (no fix really)
por
Any pictures or a walkthrough on that. I think a lot of people will want to upgrade to 4.0 to get continuity in OSX Yosemite.
por
continuity still not available.. Looks like a new machine is the only option if you want the new feature. This is so Apple
por
Exibir mais 3 comentários
Adicionar um comentário
2 respostas
Solução escolhida
It seems like the MacBook Pro 15" and 17" Unibody (Mid 2010) Airport/Bluetooth Board is different from the 2011 model. The connection looks like its the same but the placement is different which could cause the cable to be too short or too long.
Maybe it's worth a try? It won't be a snug fit though.
Imagem de MacBook Pro 15" and 17" Unibody (Mid 2010) Airport/Bluetooth Board
Produto
$29.99
Imagem de MacBook Pro Unibody (Early 2011-Mid 2012) AirPort/Bluetooth Board
Produto
$42.99
Esta resposta foi útil?
Pontuação 6
1 comentário:
I have a Mid 2010 15" and am changing the logic board to a Late 2011. My BT/Wifi board is working fine. And the cable to the logic board seems to fit fine. I just wonder if I really will just work or if I have to have a 2011 BT/Wifi board. Any experience?
por
Pontuação 0
2 comentários:
Better yet, you can use this tool if you have a BT 4/LE board in the system: Continuity Activation Tool
por
Adicionar a sua resposta
Chris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 8,751
