Ir para o conteúdo principal
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
398 Perguntas Visualizar todos
Can I use an iPhone X battery in my iPhone XS safely
iPhone XS replacement battery is quite expensive compared to the iPhone X can I just use the iPhone c battery in the Xs
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
They are very different designs!
The XS uses a newer single cell were as the X uses a dual cell. The charging logic is very different as the X uses a double tap where the XS uses a single tap. Your logic board is not designed to support the other battery charging needs. Please use the correct battery for your phone!
Imagem de iPhone X Battery
Produto
iPhone X Battery
$34.99
Imagem de iPhone XS Battery
Produto
iPhone XS Battery
$34.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ross White será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 23
Últimos 30 dias: 105
Duração total: 8,982
