No backlight. LCD and sound functional
Hi all. I have a Panasonic Viera TH-L55DT5. When I power it up, the sound and LCD work fine, but the backlight (of led strips) doesn't light up at all. I have opened the back and checked the voltage on the PSU to the best of my ability, and it appears to be over 5 volts to the main board and around 2 to the inverter board. I'm not sure if I'm checking in the right places, though.
There's no visible damage to the boards, although I'm not sure how to check capacitors. I've ordered a better multimeter which should arrive today.
I started taking apart the panel to test the LED strips, but stopped when I realised what an undertaking that was going to be.
Is there a way I can work out if one of the boards is faulty?
Boards:
Overview
Minebea CT31004 (power)
TNPA5691 (inverter)
MDK 332V-0 W (no idea what this is - found one on eBay which says "T-con board")
TNPH0993 3A (main board)
Any help would be greatly appreciated!
Esta é uma boa pergunta?
