Ir para o conteúdo principal
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 Perguntas Visualizar todos
Pressing the ZL button on device turns system off.
In hopes of trying to clean up a used system I recently bought. I opened the 2DS and disconnected the ribbon cables to get to the motherboard. When putting the ribbon cables back in place the one located next to the ZL button turn the system off completely when touched gently by the button or gently tapping the cable. I tried to re-seat the cable but nothing is working. Any suggestions, i’m at a loss. :(
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
If you followed the guide(s) they provide here, on this website, made to be a reference on how to “properly” fix things, you have opened one or both of the connectors that are very misleadingly called ZIF connectors in the guides. They are absolutely not ZIF connectors and opening them destroys them and makes the ribbon cable unable to make good contact afterwards.
Sadly the solution is to replace the broken connector(s), although I have no idea what their name is and it requires pretty precise soldering iron to do so.
Update (09/17/2020)
I found an alternate solution that has the potential to work if your connector is not too broken.
Cut thin strips of kapton tape, 2mm wide at most, by about 10mm, and layer two or more as needed on top of the ribbon cable where it gets inserted into the connector, this will make it thicker in this area and allow better contact with the connector if it is able to still provide a minimum of closing force.
Of course if your connector got lifted too much, this won’t work and you’ll need to replace it or get it replaced, which is potentially very difficult.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Andres Luna será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 442
