My PSP doesn't boot anymore after I dropped it
I dropped my PSP accidently and I found out that I doesn't boot anymore.
When I connect the charger,the POWER light shines in red.But it doesn't boot.
Also the L/R tigger buttons has fall off.
Is there anyway to fix it?Or my PSP was trashed?
Esta é uma boa pergunta?
Unfortunately your problem is a bit vague. It could be as simple as a connection coming undone and could be as serious as a damaged circuit board. Try following this guide to get into your PSP and look for severed connections that shouldn't be. With any luck, you'll just have to plug in a wire and you'll be good to go! Let us know what you find.
por Phillip Takahashi
When I push the power button while recharging,the led stays red,no image,no startup sounds and I don't think it is a connector problem.
por Honam1021
