Ir para o conteúdo principal
Liberado em abril de 2010 com as opções de processador i5 de 2,4, 2,53 GHz Core ou i7 de 2,66, 2,8 GHz Core
590 Perguntas Visualizar todos
MacBook Pro 15" Mod- 2010 Odd issues. Won't turn on.
I shut my computer off using the button of doom prior to installing upgraded RAM and battery. I am a novice at computer repai and was hoping to do a quick upgrade to my now 10yr old computer. My computer was working great up until that point. Since then I have tried powering it on many times. It won’t budge no sounds, or screen just black. My magsafe does show green and my battery indicator light shows 100%. Before the battery was fully charged it did show amber, but no blinking or dim lights. I feel like Ive tried everything short of replacing the logic board I have tried:
  • Replacing the old battery and RAM.
  • Trying every combination of old/ new battery and old / new RAM.
  • Double checked thqt the RAM WAS SEATED CORRECTLY
  • Reseting the SMC & NVRAM
  • unplugging the battery trying to run only on ac power.
  • Holding power key for ten seconds, then pressing again.
  • Disconnecting the keyboard and pwering with the powerpads on the logic board.
  • Disconnecti g the keyboard and using
  • Unplugging the battery for 5 seconds holding the power button then plugging the battery back in.
  • Powering with the battery and ac adapter.
I Really dont want to have to replace the logicboard on a 10 year old computer, but I juat wantwed to see if anyone had any other suggestions.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
What did you install for RAM? Maker, version and size
por
Timetec, 2 x 4gb, DDR3 2RX8.
por
Adicionar um comentário
1 resposta
This is what I found for your RAM: Timetec Hynix IC 8GB KIT (2x4GB) DDR3 1333MHz PC3-10600 Non ECC Unbuffered 1.5V CL9 2Rx8 Dual Rank 204 Pin, Low Density 8GB (2x4GB)
You didn’t get the correct RAM for your system! You need PC3-8500 DDR3 1066 MHz.
Here’s Apples memory guide for your system: MacBook Pro: How to remove or install memory
Esta resposta foi útil?
Pontuação 0
2 comentários:
Oh, ok. I can buy new RAM. Do you know however if it might have shorted something because I did place the old RAM back, and still no start up.
por
Its possible you damaged the sockets. Remove the RAM and look into the sockets do you see a damaged pin or the key tab?
With no RAM restart the system do you get a beep code as well as any change in the display (the color should shift a bit or just boot up to a grey screen)
por
Adicionar a sua resposta
David será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 44
