MacBook Pro suddenly shutdow never turned on
i was trying to clean dust on the Macbook pro, it suddenly shut down then never turned on. i know there was more than 50% battery left when t shut down. it is not even charging when i plugged on. my charger is new and working fine. i already tried to plug on different outlet. nothing happens, is no sign, completely dead. i know my internal battery was showing week but still i was able to work for around half an hour without connecting the power.
Esta é uma boa pergunta?
Pontuação
0
Did you properly disconnect the battery before you starting dusting out your system as well as practice proper ESD precautions?
por Dan
my charger was not attached. i was just cleaning outside not inside/
por jaga
Did you use a spray cleaner?
por Dan
