Ir para o conteúdo principal
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
301 Perguntas Visualizar todos
Does not recognize hard drive
I have not used in two years but thought would salvage it.
When I start the mac it gives a flickering folder with a question mark. After some web search I booted the system with the install CD. After startup when I try to install it says “Mac OSX cannot be installed on this computer” . Is replacing the hard drive the only solution for this ?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Please tell us what system your machine is booting into from the DVD. Does it have the original hard drive?
por
not sure if this answers your question. I do command+R with the DVD.
1) It says Mac OSX cannot be installed on this computer
2) Disk utility is showing only the DVD drive
3) Startup disk shows two options: the install DVD and "Network Startup" with a question mark on a drive.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
First boot up from the DVD by pressing the start button and immediately inserting the DVD. Hold down the “C” key to boot from the DVD. The system install page should show up. Go to the second page and the pull down menu will appear. Now go to Disk Utilities.
By holding down the command R you are booting from the repair partition on the hard drive.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for the pointers. But I got the same options as before and when I retried it just told me to restart the machine.
por
Adicionar a sua resposta
calsri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 10
Duração total: 61
