Ir para o conteúdo principal
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
Mac reboots half way to the booting screen - force to hold space bar
Hello,
if anyone can help?
I have a MacBook Air that keeps shutting down half way through the boot process. I am forced to press the spacebar and hold or tape it down in order for the laptop to boot.
I am thinking could be the power button stuck or something but I tried cleaning and nothing.
any ideas how I could fix it?
thanks,
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Did you have a liquid spill at some point into the keyboard or trackpad?
por
Hi Dan,
Yeah the wife drop some liquid. I actually disconnected the keyboard and it works.
Is there any way to clean the keyboard or is something I need to replace ?
por
Forgot to mention I check the board and there is no corrosion there nothing
Board is in pretty good shape
por
Adicionar um comentário
1 resposta
Solução escolhida
Its a bit of work! You can replace the keyboard MacBook Air 13" (Late 2010) Keyboard or if you don’t want to go that deep the easier way is just replace the full uppercase MacBook Air 13" (Late 2010) Upper Case with Keyboard iFixit is currently out of stock but its so much easier!
In either case you’ll need to strip the system down following this guide MacBook Air 13" Late 2010 Upper Case Replacement
Imagem de Replace an upper case assembly compatible with the Late 2010 MacBook Air 13 inch laptop. Includes a keyboard, palmrest area, and power button. Part #661-5735.
Produto
$99.99
Imagem de Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1369 13" MacBook Air from late 2010.
Produto
$19.99
Esta resposta foi útil?
Pontuação 2
1 comentário:
my suggestion is a replace of the case that includes the keyboard.
or if it an older one that the keyboard is a separate part number - that is fine.
por
Adicionar a sua resposta
Lex c será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 150
