Trying to restore but won’t stops on unable to write filesystem
Hi guys,
Another issue
trying to restore Using 3utools but won’t it stops on unable to write filesystem
anyone have any help or advice.
Thanks in advance
Esta é uma boa pergunta?
Hi guys,
Another issue
Thanks in advance
If it cannot write to file system it would point to a faulty NAND.
Esta resposta foi útil?
I am getting the same error. What does that mean? And is there a way to fix the issue? I am trying to flash and retain users data because my iphone XS max got stuck in recovery mode with a memory full of pictures of my kids from the last few months..
Do you think I should try another usb cable? Or not ?
The person said it is a motherboard repair. Need experience for this. @kamijo08
@rakeshkay Yes rule out a parts issue before you can confirm faulty NAND you should try different cable and PC
@imicrosoldering thanks for the reply I’ve only just seen it will give it a go thanks
I have problem like this i need to return user data iPhone 6
I had the same issue . I replaced the battery and charged it fully then flashed it with iTunes successfully without any problem. I guess battery is the culprit for me
ERROR: Unable to receive message from FDR 0B55C860 (-4). 0/2 bytes
iPhone x unable to mount file system
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 72
Duração total: 6,633
