Ir para o conteúdo principal
The McCulloch MC1275 is a heavy-duty canister steam cleaner that uses ordinary water heated to over 200 degrees Fahrenheit to clean and sanitize a wide variety of surfaces.
28 Perguntas Visualizar todos
No light when I plug in my unit!
I just took my unit out of the box, set it up, plugged it in and there is nothing happening! I pressed reset and I still can’t get anything from the unit.
I’m frustrated because I migh have to pack it up and send it back! What a wasted morning!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I also followed the instructions in the manual, unplugged it, replugged after the reset- nothing! I even tried a different outlet-still nothing!
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @ Priscilla Baskerville ,
As you say you will have to return the cleaner for a replacement or a refund.
You shouldn’t have to find out what’s wrong with a new product and you don’t want to risk voiding the warranty by opening it up to find out what’s wrong
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Priscilla Baskerville será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 811
