Ir para o conteúdo principal
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 or 2.8 GHz quad-core Intel Core i5. Released October 13, 2015.
47 Perguntas Visualizar todos
No Display back light only - can't see icons wont display externally
Does anyone know if the GPU is upgradeable or replaceable? on the iFixit teardown, I cannot see where the GPU is on the logic board or whether it’s a replaceable part?
The issue is Currently, the iMac turns on and chimes and but no display, just backlight glow and can’t see any icons using a torch. It also won’t display externally using an external display port.
Any ideas?
Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sorry, the last replaceable GPU MXM board model was in the 2011 models.
This model does not offer a dedicated GPU, it only offers the Intel HD Graphics 6000 or Intel Iris Pro Graphics 6200 which is within the CPU chip.
You’ll need a to replace the logic board. iMac Intel 21.5" EMC 2889 Logic Board Replacement
You’ll also need these tools:
  • Plastic Cards you should get two sets
  • iMac Opening Wheel or if you get the [produto vinculado ausente ou desativado: IF173-005] you’ll get the tool with it.
Imagem de Plastic Cards
Produto
Plastic Cards
$2.99
Imagem de iMac Opening Wheel
Produto
iMac Opening Wheel
$7.99
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks Dan, this is what I was thinking.
por
Adicionar a sua resposta
Craig será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 39
