Ir para o conteúdo principal
Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
101 Perguntas Visualizar todos
Is there a custom aftermarket heatsink that we could upgrade to?
just wondering if something can be adapted to help out dissipate the heat faster
Esta é uma boa pergunta?
Pontuação 7
Adicionar um comentário
2 respostas
Pergunta mais útil
Its a bit more than a heat sink that’s needed. Apple’s physical design still won’t allow the heat to dissipate via the fan.
If I was Apple… I would have created a vapor chamber which can be made thin and then mounted with a fin assembly to the side with the fan blowing across pushing the heat out.
If you look you can see there is enough room to put one in. mmm… a possible upgrade kit??? You still would need to tune the thermal management logic within the SMC as Apples thermal curve still would be biased against the improved cooling.
References:
Esta resposta foi útil?
Pontuação 1
It would most likely be very hard to upgrade the heatsink itself, however a better quality cooling paste and installing a thermal pad between the case and the heatsink would most likely help a bit.
The idea behind the current cooling solution is to push air through the system to cool everything with one fan instead of focusing a lot of cooling capacity on the CPU. If you’re okay with breaking the warranty I’d likely recommend that
Pontuação 0
Adicionar a sua resposta
Adrian Stefan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 3,394
