iMac Diagnostic LED Blinking
I have a iMac A1418 (emc 2833) that is not turning on
The Diagnostic LED #1 Blinks when the Power Cord is plugged in and if I press the Power Button it Blinks faster.
No other LEDS are on or turn on if I press the Power Button
I am thinking it may be the Power Supply but not sure. Anyone have info on testing the Power Supply?
Esta é uma boa pergunta?
Hi
Thanks for the info
I already have taken out the Power Supply and all Caps look good
So do you or anyone have some info on testing the Output of the Power Supply like you would do on a PC ATX Power Supply?
por Andrew H
Hi,
did you solve the problem? i have the same board and the same problem.
I have already exchanged the power supply but the problem is the same
Thanks a lot
por dell.alex
Hi
Not did not fix it, Had a spare Motherboard so replaced that and all good now. So look like it was the Motherboard.
por Andrew H
