Ir para o conteúdo principal
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
would a battery replacement be possible?
could someone provide the official dimensions of the battery from the xs max and the 11 pro max?
what im looking to do is to install the battery from an 11 pro max into my iphone xs max
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
@matfrags …i believe what you are looking for does not exist. there are comparisons all over the web i.e:
https://socialcompare.com/en/comparison/...
but this is not what youre looking for by my reading. best course of action is to google a replacement battery for each of the devices and hopefully one of the vendors you find list the dimensions of the actual battery. other than that, measure your battery and when you go to buy one, ask the vendor to measure theirs and compare. good luck
Esta resposta foi útil?
Pontuação 0
I think they are the same size (physically) so it should be possible. I am looking for an answer on this question as well. Both batteries run on same voltage and both have the same shape size and same connector. If you succeeded in installing 11pro max battery in an XS max please let us all know! That would be an awesome upgrade for every XS max user, including me !
Pontuação 0
Adicionar a sua resposta
George Fragoulis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 33
Ao todo: 291
