No video, only have video on DVI-i
Hello,
My 15” MacBook Pro 15 A1211, doesn’t have any image on the internal LCD, if I plug in to DVI-i port to external LCD display it works fine. What can be done?
Best wishes to you all.
Update (04/24/2020)
Thank you for your support.
To end this, i all so have mac from 2008 or 2009?? model A1181
Can i install El capitan?
Thank for all, best wishes.
Esta é uma boa pergunta?
3 comentários
Are you sure you selected the correct model here? The new 2019 16" model does not offer DVI the older Late 2008 and older models did.
por Dan
Yes, it’s 15” MacBook Pro from 2006, model A1211, it only has display image from DVI-I port connected external display.
I need to know if its a common problem from video processor or is any thing else, I ask because it only have video from DVI-I port, I believe if it was video processor problem, it won't send any signal or video...??? (Just guessing)
Can you help with it....??
It this common problem of video processor??
Sorry this post it is not for 2019 sorry, mistake, sorry.
por Luis
● 2008 ~ Early 2009 systems max-out with Lion 10.7.5
● The very last two Mid-2009 (EMC 2300) systems are able to run El Capitan 10.11.x.
por Dan
