Ir para o conteúdo principal
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
How to replace right speaker on MacBook Pro 15'' A1398
How to replace right speaker on Mac Book Pro 15'' A1398
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Did you review this guide? MacBook Pro 15" Retina Display Early 2013 Speakers Replacement
Esta resposta foi útil?
Pontuação 2
Hi. Can you please clarify about a MacBook repair. My left speaker sound distorted. I need to replace it. Can I replace only the left speaker? If the speakers should be replaced at once, can you please tell my, why.
Pontuação 0
1 comentário:
What is your exact model is it the same as this one?
There is really no reason to rush a repair unless your system is still under warranty or service contract (AppleCare+) or the extended warranty it might have is about to expire, otherwise you're on the hook for the repair.
Use the sound control panel to bias the speakers so you can identify which speaker is damaged. Then you really only need to replace the one speaker.
por
Adicionar a sua resposta
Alexandre Alexeev será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 9
Ao todo: 351
