Is my PSU bad, my motherboard, or something else completely?
A few days ago I embarked on a journey to clear my iMac of dust and replace the thermal paste. I decided to do so because I noticed that the cooling system was not able to keep my CPU & GPU temperatures under 80 degrees (even at full speed) when playing GTA V. Also the iMac is 7 years old, so I figured the overheating would very likely be occurring due to some dust buildup in the system. However once I put everything together again, the iMac would not boot.
The problem
I’ve been looking at the Diagnostic LEDs when booting and I’ve been learning about what they indicate. The first LED turns on, the second LED, however, does not. When I push the power button, the second LED lights up for about a second. During this second I hear the HDD spin up and then the system turns off again, only to (I’m guessing) ‘attempt’ to boot again, as this proces repeats itself indefinitely. Nothing else seems to happen, the fans don’t spin, I hear no boot sound, and the third LED remains off as well (obviously).
Where it might have gone wrong
When replacing the thermal paste and having to put on the heat sink again, I found it tough to hold back the CPU retainer and screwing it in at the same time. This lead to me being a bit rough with the heat sink.
Later that day I noticed that the PSU was baking in the sun and immediately took it out, thinking it could be harmful to the piece of hardware.
When connecting the tiny connector from the motherboard to the PSU I also felt like it was bending a little too much to my taste. However, I did not think much of it as it seemed the connector could handle a bit of bending.
I’ve also read someplace that it could have something to do with the RAM, though I don’t think I’ve really touched it.. Also it is incredibly difficult to remove as I have all four slots filled.
Troubleshooting
This is where I am in need of help, I have another iMac laying around (late 2015 21.5”) and I have an idea of using it to troubleshoot and I would like your opinion:
- Checking if the PSU is the cause by trying to boot the iMac using the lower wattage PSU from my 21.5” iMac. I’ve been thinking this lower wattage shouldn't matter as long as I don’t perform any tasks that require more CPU and GPU usage. (Would there be any compatibility issues? Could this damage other components
I’ve also been thinking about removing all the RAM except for one DIMM, however, they seem quite hard to remove. Has anyone got any tips?
Possible repairs
I’ve noticed a hole in one of the solder joints on the PSU, could this be the problem? And how would I fix the solder joint? (See images below)
In conclusion
I would like to know if there is a sure way to tell that the PSU is bad, and not the motherboard. Also if there then would be a way to fix it, or if it boils down to having to purchase a new PSU.
Thanks for your thoughts in advance.
Esta é uma boa pergunta?
