Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Perguntas Visualizar todos
Why can't I turn the phone on?
I took the front off of the phone to place the 1 tab back into position as I was getting a white screen issue. After putting the phone back together I couldn't get it to turn back on. I didn't even fully take it apart, only lifted the screen long enough to put the tab back into place. Any suggestions?
Esta é uma boa pergunta?
Pontuação 12
Adicionar um comentário
6 respostas
Pergunta mais útil
check that the lock-switch connector is on fully, as there may be no hardware failure, but somthing preventing you from turning it on.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Where is the lock-switch connector?
por
Where is the lock-switch connector located?
por
Om the right corner o.
por
i think my phone have hardware problem
Update
please show me phones diagram
Pontuação 2
1 comentário:
gayan, it would work so much better if you ask your ow Click on the link on the right side of this page. "Ask a question" and give as much detail as possible.
por
my samsung s4 is not working it fell the screen cracked and the mother board not working i cant switch it on
Pontuação 0
wen i turn un my phone it stop by the starting tone
Pontuação 0
why cant my phone turn on
Pontuação 0
My G3 Phone can not on
Pontuação 0
2 comentários:
por
Please what shall I do?
por
Adicionar a sua resposta
shannon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 1,979
