Ir para o conteúdo principal
Vodafone is a global telecommunications company based in London, England. The company manufactures cellular phones in addition to operating cellular networks.
19 Perguntas Visualizar todos
How to get water out your phone?
Water has got into your phone already have put in rice after 2 months
isn't oning but doesn't work
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
It may already be too late for the phone to be saved, but you can only try.
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Rice does not fix the problem, especially problems caused by corrosion
Rice is for dinner, not repair
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion etc. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do check the label to verify the amount of IPA. The higher the percentage the better.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
You may have to replace the battery as it may have become depleted beyond recovery.
You do not state the model number of your Vodafone phone, so you may have to search places such as YouTube to find teardown videos that will help you to open the phone so that it can be inspected and cleaned properly
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Bernice Lawal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 41
