WiFi won’t work
My WiFi won’t work at all it won’t show any connections but my Bluetooth is working could it be my flex cable or would it be an air card issue.
Esta é uma boa pergunta?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 67
Click on the WiFi icon while passing on the Option key. Your menu will show additional information. I would run the Diagnostic Report to get a better idea what's happening. It does take a bit of time post it here for us to see. Adicionar imagens a uma pergunta já existente
por Dan
Unfortunately it modem I use is In my roommates room so I can’t plug an Ethernet cable in to add a picture that way would I be able to add one upswing my phone? It’s also not letting me run a diagnostic on it but when I go to check my WiFi status it says everything is null, my Bluetooth word fine I can pair devices no issue.
por Gage
There is always sneaker net! Use a USB Thumb drive to copy the file off. You should be able to leverage your cellphone using bluetooth tether mode as well. How to Turn Your Phone into a Wi-Fi Hotspot
Are you sure your roommate left the his WiFi router connected/powered? It sounds like he went home so you lost your WiFi AP.
por Dan
