Battery Replacement causes trackpad issues
So I replaced older battery with a new battery and after the install I noticed that the trackpad wan’t functioning properly as it once did. It’s annoying to use and I was looking for a solution to fixing this issue without having to get another battery that may or may not fix the problem.
Esta é uma boa pergunta?
1 comentário
What appears to be the issue? Are you able to slide your finger across and up and down on it having the pointer follow your actions? Or is the click action not working?
por Dan
