Mac Mini no display or chime
Hi,
I have Late 2014 Mac Mini. As soon as it gets power it automatically turns on and fans starts spinning. Black display lights up with no chime and keyboard caps light doesn't turn on (it means keyboard is not getting power). When I connect my WD External hard drive its light starts blinking.
I also tried booting with macos bootable usb but no success.
What could be the problem?
Any help would be appreciated because there is no official Apple Store in my country.
TIA!
Esta é uma boa pergunta?
5 comentários
Can you give us a bit more here, did you alter anything internally? change the drive and RAM?
Do you have the system and its display on a surge suppressor or UPS?
Did you hear a noise or smell anything burnt?
por Dan
@danj No its RAM is soldered on the board and the person who sold it to me said he was doing something with clover bootloader anything like that. System and display is directly connected with main supply no UPS etc.
por Subhan Riyaz
1. Did it ever work before?
2. Did you buy it broken?
3. First remove all keyboards and check if no port or connector is broken and clean. Then try SMC reset:
https://support.apple.com/en-us/HT201295
4. Open and see for any smell as Dan says.
5. Open and gently unplug and replug every part.
see Mac mini Late 2014
por bmx2019
@bmx2019
1. Yes, I bought it from my friend and I also used it myself a lot.
2. Yes.
3. I disassembled it and none of the connector is broken. I am getting power from all four but keyboard is not connecting.
4. It smells normal no bad smell.
5. Yes I opened it already and disconnected the hard drive and tried to boot from bootable Usb but no luck.
por Subhan Riyaz
> clover bootloader
You should have posted this on your original question. Would have helped save all of us time.
as Dan says below.. good luck
por bmx2019
