Ir para o conteúdo principal
Cozmo is a tiny robotics toy designed and created by the Anki Software company. Cozmo has features that allow it to interact with its environment, such as facial recognition, emotional display, and the ability to move.
19 Perguntas Visualizar todos
Cosmo is not lifting the cubes up
Cosmo not lifting the cubes up..what's wrong with him
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
5 respostas
the lifthook is missing
Esta resposta foi útil?
Pontuação 0
If your cozy won’t lift up cubes you will want to get a new lift motor or buy a brand new cozmo
Pontuação 0
1 comentário:
I am 100% right
por
Cozmo arms are not working
Pontuação 0
Take of the arms check if anything is in there if there's not then you might have to get a new Cozmo
Pontuação 0
take the arms off and under one of the bottom ones there is a large cog, use a pair of tweezers to rotate it 180 degrees, but be carful not to touch the rotation sensor
Pontuação 0
Adicionar a sua resposta
James Honeyman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 843
