A better view of the rear speaker connector
I dismounted this part (separating it from the motherboard) as the guide show, but now I need to see clearly how to connect the this part to the motherboard. Thans
Update (03/14/2020)
Thank you for your reply. According to your explanation I see that I may have made a big mistake while trying to remove the connector and I may have broken the connector.
The cable has come loose and the base has peeled off from the motherboard. Attached photos.
Can this mess be repaired?
Thank you very much
Update (03/15/2020)
Here’s the pictures of the logic board:
Many thanks for your help.
Roberto
Update (03/18/2020)
To @danj.
The macbook wouldn't start so I sent it to Apple's service, the answer was that the motherboard was damaged. And given the high cost of this repair, I decided to do it myself. And here I am learning. Although up to the hour I've only learned to break things.
So I had already ordered a motherboard on the link you recommended (I will have it this week). I would please ask you to explain to me why I have to change the fan. I'm sending you a picture of the fan and its connector.
Many thanks
Esta é uma boa pergunta?
7 comentários
Sounds like you lifted the connector off the logic board, pulling both the cable and the logic board sides off. How about posting a picture here for us to see Adicionar imagens a uma pergunta já existente
por Dan
Can you take a picture of the logic board like what I have so I can see how it looks
por Dan
@robema - I guess you don't need the fan after all!
por Dan
@danj - Ok. thanks . I still have doubts about the connectors I've ripped off the motherboard. Do I have to separate a portion of them in order to connect them to the new board? Could you show me some pictures showing this separation? Thanks a lot
por roberto
@robema - Not following you here... The new logic board with have the connector in place.
Think it like a wall plate outlet and you are plugging in a lamp. If you break the lamp plug then you need to replace that, if you damage the wall place outlet you'll need to fix that. Here we are taking the lamp down the street to a new house with its own outlet in the wall.
por Dan
Exibir mais 2 comentários
