Why says check lint screen . What’s that?
My dryer he3 it say check lint screen
Esta é uma boa pergunta?
This is your lint screen. You must clean it after every dryer cycle.
Esta resposta foi útil?
just a follow up to the previous post, from experience if after cleaning the screen and the error is still present, there is likely a clog down inside. could possibly use a vacuum to clear or may need to disassemble and clean to clear if all else fails. also, depending on the unit you have , you may need to manually clear the code after cleaning. would want to do a google check to see if applicable for your model.
Here's a video on deep cleaning it if you have already been doing what Travis told you:
Thanks mayer. I probably should have posted that too but couldn't find the one for his dryer. That is the same screen but I have different dryer.
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 65
Duração total: 1,949
