Ir para o conteúdo principal
The Motorola Moto X4 is the 4th generation phone in the Moto lineup. It features a 5.2" screen and is IP68 rated. Model number XT1900-7, XT1900-5, and XT1900-1
24 Perguntas Visualizar todos
Why doesn't my x4 boot up?
What is there in the back of a Moto X4 that prevents phone from booting up? I've replaced motherboard, charging port, battery and phone still won't start. When I put the same parts into a Moto X4 with a cracked back, everything works, but not when I put them into the back I want to use - its in perfect condition. HELP!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
J W Fred Klein  since everything works until you try the new back the issue will be with that. Check to ensure it is identical to your old back and that it does not shorten anything out or pinch some flex cables etc.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
J W Fred Klein será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 229
