Ir para o conteúdo principal
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
MacBook air (mid 2009) beeps every five seconds after keyboard connect
Hi!
So, I was trying to fix a mid 2009 (A1304) macbook air and concluded the keyboard was probably broken. So, I disconnected the ribbon cable for the keyboard and started the macbook using the power pads, and it worked!
Genius as I am, I (let’s say accidentally) reconnected the keyboard ribbon connector while the computer was booting. After that, it will only give me a beep every five seconds.
Now, I know this is stating there is a ram problem, but since the ram on a macbook air is soldered onto the logic board… does this mean this macbook air is probably fried?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Ouch! Not good!
Yes you do need to make sure things are off before connecting or reconnecting things. Time for a new logic board sorry ;-{
Esta resposta foi útil?
Pontuação 1
1 comentário:
If that's the case, it's time for the trashcan
por
Adicionar a sua resposta
Timbobs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 169
