system memory is damaged
Esta é uma boa pergunta?
Try formatting the systems memory should fix the problem. The manual for the DSi is available here and might also work for you. Check page 85 of the manual. Good Luck.
Esta resposta foi útil?
What if I don't want to delete everything I have is there a way to repair my system memory?
It worked. Thank you.
did you delete all the memories
My Dsi says the memory Is damaged... How do I fix it?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 6,436
